Companion bug
mpy
Companion bug
Post by mpy »
Hello, I am using XnViewMP 0.93.1 64bits (Mar 7 2019) on Linux (Arch) and my settings for companion files are
[ ] - Show Companion
[x] - Delete
[x] - Copy/move/Rename
I experience issues with upper case file extensions; here are some cases:
1) Initial directory content:
DSCN0055.JPG.xmp
2) Copy "DSCN0055.JPG" within XnViewMP to the same directory. Directory content now:
Copy of DSCN0055.JPG.xmp
DSCN0055.JPG.xmp
OK
3) Delete "Copy of DSCN0055.JPG" within XnViewMP. Directory content now:
DSCN0055.JPG.xmp
OK
4) Rename "DSCN0055.JPG" within XnViewMP to "DSCN0055_test.JPG". Directory content now:
DSCN0055.JPG.xmp
Faulty!
The expected behavior would be that also the companion is renamed to "DSCN0055_test.JPG.xmp", as it is working when using files with lower case file extensions.
I tried to add "JPG" (upper case) to the companion definition as master extension, but it is automatically converted to lower case once editing is finished.
Can anybody reproduce this behavior?
Thanks a lot!
Re: Companion bug
:bugconfirmed: Thanks to your detailed description I can reproduce. It works if we have .jpg and not .JPG
Re: Companion bug
Re: Companion bug
mpy
Re: Companion bug
Post by mpy »
I can confirm that the problem as described is solved in XnView MP 0.96 (using 64bit version on Arch Linux). :)
Thank you very much!
I also tested the "Batch rename" function. There a little quirk remains here, when you activate "Extension" and/or "Case" option, to convert the Base file extension to lower case. Example:
DRX00998.JPG.xmp
gets renamed with "Case = Extension lower case". Result:
renamed.JPG.xmp
Re: Companion bug
mpy wrote: Sat Mar 21, 2020 5:15 pm I also tested the "Batch rename" function. There a little quirk remains here, when you activate "Extension" and/or "Case" option, to convert the Base file extension to lower case. Example:
DRX00998.JPG.xmp
renamed.JPG.xmp
could you create a new post?
mpy
Re: Companion bug
Post by mpy »
Done: Companion bug in "Batch rename" (viewtopic.php?f=62&t=40179)
