The „IPTC Dialog” doesn’t edit data anymore!
To test it,
1. download the attached file to a folder of your choice
2. navigate with the browser at the attached file
3. Press Ctrl+I in order to show the IPTC dialog
4. In „Caption” field modify the text - for example add „qqqqqqqqqqqqqqq” at the end.
5. Press „Write”
Expected:
When we press again the Ctrl+I, the „qqqqqqqqqqq” string should appear.
Actual:
Nothing was saved. The old text is there.
Note:
It seems that if there isn’t any value in the field (that is the field is created) then the data is saved. In other words, creation works ok, just the modification has problems.
It would be marvelous if we will have a fix for this ASAP.
Ready to test!
Nasty bug in 0.94 with the metadata
m. Th.
Re: Nasty bug in 0.94 with the metadata
I could not reproduce with my own photos ...
... nor with yours
... nor with yours
Catalogage avec XnviewMP :
What version do you have?
I can reproduce it at will with any (?) JPG photo.
Perhaps I should mention that only Editing has problems.
m. Th.
V0.94. Win 7 pro.
When caption is modified :
- I can see the new text using Ctrl i again.
- If I don't release and select again the same photo, I won't see new value in Info pane, but I know that metadata are updated.
- Labels aren't refreshed too (I added caption as a label below my thumbnails). To get new values in labels, I must select another folder, and come back to previous folder
- I didn't notice any change in these behaviours since 0.8x versions
- Did you try to mark/unmark the third option in the least tab : "replace only if original value is empty"
Thanks a lot for the help!
...however it is nasty, nasty, nasty bug!
How I „fixed” it:
However with these settings in 0.94 the behavior is different: the settings are honored now even in the case of a single file (thing which I think that is more logical), even if they are grayed (thing which is bad).
So I selected 2 files just to change the settings and it worked like a charm.
Tested with one and many files.
So, the bug exists, but it is a little bit different and much easier to fix:
1. Make the options always enabled
2. Take out the „Multiple selection” text from the Options tab
How I „fixed” it:
Going to Options (last tab in IPTC dialog) I noticed that the options are greyed there and all are checked. Same like in 0.93 and earlier.- Did you try to mark/unmark the third option in the least tab : "replace only if original value is empty"
m. Th.
