Layers and App Window Size
crazydaz
Post by crazydaz »
1. Can someone tell me if that is the correct behavior for XnConvert (1.80, macOS):
Converting TIFF/PNG/PSD with layers to TIFF/PNG/PSD = Flat file?
2. What are the minimum App Window dimensions? Any chance to go below the minimum window size? If not, are there any plans to implement this?
Re: Layers and App Window Size
crazydaz wrote: Wed Nov 20, 2019 2:22 pm 1. Can someone tell me if that is the correct behavior for XnConvert (1.80, macOS):
yes
what do you means?
crazydaz
Post by crazydaz »
xnview wrote: Thu Nov 21, 2019 2:40 pm
yes
what do you means?
805px x 620px~ is the smallest XnConvert window I can achieve when resizing it. What are the reasons for the limitation? When I already have predefined presets, there is no reason for me to go and change any settings , as such there is no reason for having such large XnConvert window having open...
Any chance to add simple sliders on at the bottom and the side? Just like in firefox or chrome when you resize it to e.g.: 100px x 100px ~.
the output tab need some space
