Since this program catalogs the location that all thumbnails refer to, it shouldn't be too difficult to have a switch where the directory tree shows either the full tree or only those branches with thumbnails.
While it would be more work, I would also suggest that this function be tied in to the filter so the tree would change based on what type of file you were looking for.
Option to show only directories with scanned thumbnails.
coolhandluke
Re: Option to show only directories with scanned thumbnails.
Perhaps it will be better to have a special items in categories filter pane instead of folder pane
