Toggle View
mapline
Toggle View
Post by mapline »
Want to view to toggle to show RAF and/or Jpeg.
If I change custom view to exclude JPEG it doesn't show JPEG in custom filter however if changed to All it filter it still doesn't show JPEGs.
Am I on the wrong track?
Thanks
Re: Toggle View
sorry but not possible to switch between the jpeg and RAW
mapline
Re: Toggle View
Post by mapline »
Hi Pierre
Thanks for the answers.
A work around I found is to filter by type and then switch between ascending and descending which switched list of order of jpg's and Raf's.
Can I make a shortcut key for the ascending/descending.
Thank You for the program.
Michael
