Old bug again [No Refresh, metadata missing]
toyotadesigner
Hi Pierre, with the new 0941 the old bug returned:
viewtopic.php?f=82&t=39547v
Version 0940 did not have this bug...
hobbyists discuss new camera features
photographers discuss new software
masters discuss light
Re: Old bug again
Please describe a way to reproduce
toyotadesigner
Re: Old bug again
See the link, we have already discussed this topic
Re: Old bug again
Could you post a detail way to reproduce within XnView?
toyotadesigner
Re: Old bug again
Scenario # 1
01. Start XnView MP
02. Select a RAW/NEF image
03. Open with RPP (RawPhotoProcessor mac OS)
04. Develop the image
05. RPP writes the resulting TIFF to the original directory
06. Temporary image appears for a second in XnView
07. RPP updates the EIXF data of the developed image
08. Final TIFF appears in XnView MP and is sorted next to the original RAW (as specified in the settings -> sort by »Date taken«)
09. TIFF has only filename and Date
Scenario # 2
01. Start XnView MP
02. Select a TIFF image
03. Open with PhotoLine (mac OS)
04. Modify the image
05. Scale down the image
06. Save the image with the same filename as JPEG
07. Final JPEG appears in XnView MP and is sorted next to the original RAW (as specified in the settings -> sort by »Date taken«)
08. JPEG has only filename and Date
Scenario # 3
01. Start XnView MP
02. Select several TIFF images
03. Open with Hugin Panorama Stitcher (mac OS)
04. Stitch the image
05. Hugin writes temporary TIFF files to the original directory
06. Temporary images appears in XnView
07. Hugin performs the final stitch and updates the EIXF data of the panorama image
08. Final TIFF panorama appears in XnView MP and is sorted next to the first original RAW (as specified in the settings -> sort by »Date taken«)
Hitting the »fn + F5« key refreshes the thumbnail view and the rest of the data appears in the thumbnails.
Alternatively switching to another directory and back does the same trick.
01. Start XnView MP
Scenario # 2
01. Start XnView MP
Scenario # 3
01. Start XnView MP
Re: Old bug again
are you reproduce this problem by using XnView MP tools, and not external app?
toyotadesigner
Re: Old bug again [No Refresh, metadata missing]
I use XnView only as a light box, not the built-in tools.
This problem is supposed to be fixed in XnView MP 0.94.2. Please check and confirm the bug fix here.
toyotadesigner
Sometimes the bug returns, sometimes everything is ok.
But now there is a new bug: If I select several files in a row and press DELETE, the images are not deleted. They stay there.
toyotadesigner
Another test today and everything seems to work...
Catalina with its bug is driving me mad.
joyeux noël et bonne année!
toyotadesigner
Today I have deleted the current XnView MP version (0.94.2)
Then I deleted all files in ~Library/Caches
Rebooted
Installed XnView MP 0.94.2 again
Opened some TIFF files, scaled them down and saved them as JPEG files.
Everything ok, image data are visible.
Later this weekend I will render some panoramas with Hugin and post the results here.
Rebooted
