[0.94.1]Zoom textbox steals focus
BK201
Post by BK201 »
XnView: Version 0.94.1 64bits (Nov 21 2019)
Platform: Windows 10 (1703)
Problem 1: The zoom percentage textbox always steals focus of the newest image tab, unless there'is only one tab
Reproduce:
1. Check Option>General>"Allow only one instance of XnView"
2. Open image A, then open image B
3. Press "+" button on keyboard
Expectation:
Image B zoom in
Actual result:
Nothing happened except you typed a "+" into the zoom percentage textbox
Demo:
Problem 2: Your focus can't "escape" once the zoom percentage textbox had it
Reproduce:
1. Open image A
2. Click in the zoom percentage textbox
3. Click on image A (or anywhere of the application), then press "+" button on keyboard
Expectation:
Image A zoom in
Actual result:
Re: [0.94.1]Zoom textbox steals focus
BK201 wrote: Tue Nov 26, 2019 8:21 am Problem 1: The zoom percentage textbox always steals focus of the newest image tab, unless there'is only one tab
i can't reproduce, focus is not on zoom field.
BK201
Post by BK201 »
xnview wrote: Wed Nov 27, 2019 3:01 pm
Did more test, 2 more things need to do
1. You need to double click on image file to open it, dragging images into xnview won't produce such bug
2. Option > general > Mode when starting with a file : normal
If still have problem to reproduce it, please check my config file, it's a fresh new one (only options mentioned above are changed) I used to reproduce it
Config: https://pastebin.com/5B4HtjxS
p.s. My Option>Integration>Paths are (in case it's not included in the ini file):
Use .ini in folder: program
Catalog (.db): program
Thumsnail database: Same as catalog
Other files: program
I've sent you a PM
BK201
Post by BK201 »
xnview wrote: Fri Dec 06, 2019 10:35 am :bugconfirmed: Thanks to your detailed description I can reproduce the problem.
I've sent you a PM
The patched .exe fixed the problem, finally got rid of this annoying bug, thanks! (> 3<)~❤
This problem is supposed to be fixed in XnView MP 0.94.2. Please check and confirm the bug fix here.
