Full screen RAW issues
grimdar
Post by grimdar »
Hi all,
After checking the option "Camera Raw, use: Half Size", anytime I go fullscreen on any raw file there is severe yellow tint to the image. If I go back to Camera Raw use "Embedded Preview", it doesn't occur.. however then the image is not sharp enough (these are 60mp images)
I tried with Sony RAW and Canon RAW files.. all display yellow tint. Any ideas? It only shows this way in XnView and not other programs.
Re: Full screen RAW issues
Do you have tried to change settings in 'Load formats>Camera RAW'? I use dcraw RAW engine, and this can happened following checked options
