DNG RAW problem
Geos
DNG RAW problem
Post by Geos »
When I try to open DNG RAW files from a Yi M1 m4/3 camera I only see a 160x120 thumbnail, no actual RAW file.
Re: DNG RAW problem
Geos wrote: Sat Nov 30, 2019 7:15 pm When I try to open DNG RAW files from a Yi M1 m4/3 camera I only see a 160x120 thumbnail, no actual RAW file.
Please check, in the viewer, File > Format settings... > Read tab -- Camera RAW for the available viewing options...
This is a common enquiry, any suggestions on how the user interface might be modified to avoid confusion, a warning message displayed, perhaps?
Geos
Re: DNG RAW problem
Post by Geos »
Thank you. A "check viewing options if your files do not display properly" with a check box not to show again might work.
Re: DNG RAW problem
Geos wrote: Sat Nov 30, 2019 8:00 pm A "check viewing options if your files do not display properly" with a check box not to show again might work.
Or maybe something like, when a RAW file is opened, Viewing options for Camera RAW files can be set in Files > Format setting...
And sure, a Do not show again option.
An alert of some kind is needed... :!:
