.xmp file litter
Geos
.xmp file litter
Why are .xmp files littering my folder when I open in MP? Is there a way to prevent that?
Re: .xmp file litter
whats the problem with .xmp files?
Geos
Every time I perform an operation on a file & save XnViewMP dumps an .xmp file in the folder. Are these supposed to be temp files?
.xmp are created if you change xmp metadata, check your settings>Metadata
Geos
I'm not changing metadata and Update or create XMP Sidecar is unchecked.
how do you reproduce that?
" View, Update files from catalog"how do you reproduce that?
(2016/11/28) viewtopic.php?f=83&t=34226
I think it's a bit inconsistent to uncheck the "export" and "create a sidecar" options, to create and export a sidecar ...
but it is useful ... if someone needs to write exif data into a sidecar file
Catalogage avec XnviewMP :
Geos
Reproduce what?
To have a new .xmp added, which feature do you use?
