Moving images inside 0.94.1 [Mac Catalina]
blackxacto
Hello, love XnViewMP. In the latest version opening in Catalina, I cannot move images with my cursor. So I just renamed the images and sorted by name. Did I miss turning something on?
Learning to mind my own business.
Re: Moving images inside 0.94.1 [Mac Catalina]
no problem with previous version on catalina?
seems to this bug
seems to this bug
blackxacto
This is the first version of Catalina I have used. I had to wait till last week to move to it. Appreciate you sending the bug report. I can name and re-sort, so not crucial at this point. Love using your app.
Additionally, I have recreated the black background I like, but the far left col, I have forgotten how I changed it the last time. Would appreciate where I change its background to black? Thank you.
i means previous version of XnView MP?
blackxacto
Pierre, are you saying to use the version BEFORE XnViewMP 0.94.1?
yes pleaseblackxacto wrote: Fri Dec 06, 2019 2:10 pm Pierre, are you saying to use the version BEFORE XnViewMP 0.94.1?![]()
blackxacto
Yann67
Had the same problem. Unable to move thumbnails in version 0.94.1. Clicking and move the cursor would create a selection zone, not move any thumbnail. I switches back to version 0.93.1 and it works just fine !
Hokr
I have the same issue, where I can download older working version?
Versions back to the original 0.94 can still be downloaded from the XnView MP - General Support forum heading, earlier versions from the following link if you scroll well down:Hokr wrote: Thu Jan 16, 2020 10:12 am I have the same issue, where I can download older working version?
Old Versions
Hokr
Thank you. Moved back to 0.94 and everything works just fine on Catalina.
Please check 0.95 versionHokr wrote: Fri Jan 17, 2020 7:03 am Thank you. Moved back to 0.94 and everything works just fine on Catalina.
