Renaming folder uppercase / lowercase in folder tree pane
Crysler
Post by Crysler »
Small bug: when you try renaming a folder in the folder tree pane and the only thing that you change is the case of one of more letters, this is ignored.
Example: folder named "Test" can't be renamed to "test" or "TEST" or "tesT".
Works fine in the main window, only the folder tree pane seems to be affected.
XnView Classic for Windows, v 2.49.1, Win10
