I would like to have a "save all" or "save all as" command.
Ideally what it would do is save all the open images as image_1.jpg, image_2.jpg,image_3.jpg......and so on.
Is this possible?
save all - command request
Re: save all - command request
You can use "Sequence convert" (Ctrl+N) or - select files, copy to other folder, select files again and press F2 to rename...philip_148 wrote:I would like to have a "save all" or "save all as" command.
Is this possible?
save all images from clipboard
Sorry, I probably wasn't clear on my suggestion.
What I suggest is for all images that were added from the clipboard to be saved using a single command. The images would all be saved with a base filename and user selectable format (.jpg, for example).
But using batch convert .....
If I try the batch convert it requires that all the files are saved to disk already. Am I right?
What I really want to be able to do, thought, is batch save all open files. Is that possible? If it is I don't see how to do it.
a save all command would be pretty nifty and highly useful, but until then the only advice i can offer is to use "print open images" and print them to file/ pdf or something of that sort... but thats the best I could come up with
