I have videos and images in a single folder, and I'm noticing a difference in version 0.94 vs. 0.94.1 when using sort by EXIF Date Taken. To complete the story, note that I manually set File: Creation Date to the date the video was taken.
* 0.94: when sorting by EXIF: Date Taken, xnviewmp uses the File: Creation Date for videos since EXIF: Date Taken does not exist, and for me, videos and images appear nicely in actual chronological order when using sort by EXIF: Date Taken.
* 0.94.1: setting sort by EXIF: Date Taken results in all videos shown first, then followed by all the images which is not what I'd like to have. Maybe this change compared to 0.94 is related to https://www.xnview.com/mantisbt/view.php?id=1690.
As of now, I'm unsure as to the target behavior of xnviewmp for sort by EXIF: Date Taken, when sorting images and video. All I can say is that the behavior of 0.94 is - at least for me - the desired one.
Thanks,
Georg
Videos and images: sort by EXIF Date Taken in 0.94 vs 0.94.1
flatfield
Re: Videos and images: sort by EXIF Date Taken in 0.94 vs 0.94.1
yes, you need to add in your xnview.ini to have same behavior of 0.94
useFileDateWhenNoExif=1-
flatfield
That's it, thanks!
Best regards,
Georg
Best regards,
Georg
bhein
A lot of popular devices set the "Media created" field for videos instead of "Date taken". In order to present a slideshow with both, photos and videos, in the correct order, it would be great if "Media created" could be used when "Date taken" is missing. Is that possible already?
bhein
Any chance to get this into XnView? This seems to be also what Windows Explorer is doing when you sort by "Date". There photos and videos are sorted together nicely in chronological order.
Currently i don't know how to extract this metadata from mov, i need to searchbhein wrote: Tue Feb 18, 2020 6:51 pm Any chance to get this into XnView? This seems to be also what Windows Explorer is doing when you sort by "Date". There photos and videos are sorted together nicely in chronological order.
cousinhub38
So it was OK in 0.94.1
In 0.95 i put
in the xnview.ini (at the second line, after [start])
and i restart xnviewMP.
Setting sort by
EXIF: Date Taken
results in all videos shown first, which shouldn't (as I understand).
Note that my mp4 videos do have a Creation Date, which (as I understand) should be used when useFileDateWhenNoExif=1
In 0.95 i put
Setting sort by
EXIF: Date Taken
HP
you have not the same sort in 0.94 & 0.95?cousinhub38 wrote: Sun Mar 01, 2020 2:58 pm So it was OK in 0.94.1
cousinhub38
Well i don't know in 0.94.*...
I said
I said
according the current post (from flatfield)So it was OK in 0.94.1
HP
sorry, you have not the same sort in 0.94.1 & 0.95 (using the xnview ini setting)??
