upon test-batch converting pngs to webp with xnviewmp 0.94.1 (linux), i made sure to tick option "delete original", but for some unknown reason, the png files are still to be found in their respective locations.
what am i missing?
xnviewmp batch converter - file deletion issue
xn-viewer
xn-viewer
Re: xnviewmp batch converter - file deletion issue
for testing purposes, i ran xnview portable (via wine).
file deletion is fine with the batch-converter on this end. perhaps a bug in xnviewmp?
xn-viewer
it is the same with xnconvert for linux, so i believe it is originally a bug within this software.
really no one with similar problems here?
xn-viewer
i found this old thread dealing with similar problems.
viewtopic.php?t=30588
playing around with Settings>General>File operations recylce options as a workaround was not much of a help though.
and if you don't use 'core' option?
xn-viewer
yes, that's it.
disabled multicore and it is fine. too bad i want to convert many files, will take forever to finish
If 'delete' is enabled + multi core, you should have a message box. Currently there is an issuexn-viewer wrote: Mon Dec 23, 2019 11:03 am yes, that's it.
disabled multicore and it is fine. too bad i want to convert many files, will take forever to finish![]()
xn-viewer
sorry, don't exactly remember.
i know there was some sort of message box: multicore only avaiable with 'überschreiben - keine rückfrage / overwrite - no feedback'
but this option is already enabled, as you can see.
