0.94.1: Rename current date does not apply format
mini_jay
Post by mini_jay »
XnView: MP 0.94.1 - 64 bit
OS: Linux - 64bit
"{Current Date [Ymd]}" string in rename (Modèle de nom) does not show in renamed files at all.
Other strings such as {Accessed Date [Ymd]}, {Modified Date [Ymd]}, and {Creation Date [Ymd]} do work perfectly.
Effect: Files are not renamed correctly using the provided template.
1. Select two or more files;
2. Press F2, the rename dialogue box shows up;
3. Click on the arrow next to template text box and select "Date actuelle"
4. Re-click on the arrow again and select "Variables pour le format des dates" and select, for example, "Y - Année";
5. Check the "Nouveau nom" column in the rename preview list.
Actual behaviour (bug): Renamed files are: .png, _02.png, etc
Expected behaviour: Renamed files should be: 2019.png 2019_02.png, etc
Re: 0.94.1: Rename current date does not apply format
