Can't delete image from categoriy
farid
Post by farid »
Why images aren't deleted from category by 'Remove from category' in tabsheet Categories Filter? But images from subcategory are succesfully deleted.
Re: Can't delete image from categoriy
you can't remove root categories?
farid
Post by farid »
Yes. For instanse, I have Family->Child->Child's holiday and can't remove assigned to image subcategory Child, but can remove assigned subcategory Holiday by right button pop-up menu 'Remove from category'.
farid wrote: Sat Dec 21, 2019 10:48 am Yes. For instanse, I have Family->Child->Child's holiday and can't remove assigned to image subcategory Child, but can remove assigned subcategory Holiday by right button pop-up menu 'Remove from category'.
do you use Catalog only?
farid
Post by farid »
Can remove.
Can't remove.
could you post a screenshot of settings>Metadata?
farid
Post by farid »
Settings>Metadata.
so you use catalog only, i've tried and no problem. when you click on 'Remove from categories', the number between () changes?
farid
Post by farid »
Number in () not changes (Remove from category or Remove from all categories).
farid
Post by farid »
Made new Category and Subcaterory, copied "images" to Category and began moving to Subcaterory with mouse. At first time moving was well, then (after 194 images) problem appeared again (can't remove from Category).
farid wrote: Sun Jan 12, 2020 10:29 am Made new Category and Subcaterory, copied "images" to Category and began moving to Subcaterory with mouse. At first time moving was well, then (after 194 images) problem appeared again (can't remove from Category).
I 've tried to add 250 images to a category, and remove them after, and no problem.
How do you add files to category?
farid
Post by farid »
Return to ACDsee, which hasn't any problem with categories.
