Thank you for the "convert" Feature
Rick
Post by Rick »
Thanks again. I just discovered something that ACDSEE would not do
I can covert all my PSP, PSPIMAGE and the ancient TUB files to PNG and saving the transparency as long as there are no layers involved.
This is going to save me days of work as Ihave a gazillion of them
If this sounds like a noob :Gee whiz" discovery I assure you it is not. Most commercial graphics programs will not touch these files and they have to be opened individually in Paintshop
Thanks again!
Rick
Re: Thank you for the "convert" Feature
Thanks to use it! :D
