Subject: 0.94: Can't drag & drop to move files
derek168
Post by derek168 »
XnView: MP 0.94 - 64 bit
OS: macOS Catalina /64bit
Can't do the drag and drop to move photos to another folder since 0.94. I have no issue in 0.93 so have to rollback to 0.93.
Effect: No negative impact, just inconvenient to manage photos
1. Tag the photos you want to move
2. Sort by the tags
3. use Shift+click to choose all the photos
4. drag to other folder
Actual behaviour (bug): fail to drag & drop... can't see file icons are moved, and photos are not moved too.
Expected behaviour: can successfully drag and drop to move photos just like 0.93
______________________________________________________
Re: Subject: 0.94: Can't drag & drop to move files
it's a known issue between QT API and Catalina. I'll update the version soon
derek168
Post by derek168 »
Thanks for your confirmation and look forward for the improvement.
Best regards, Derek
derek168 wrote: Sat Jan 04, 2020 8:27 am Thanks for your confirmation and look forward for the improvement.
Please check 0.95 version
