Error : Cant find Stub Slide.exe
flip
Post by flip »
I'm new to XNview. Just playing with the slideshow feature, and trying to make an SCR or EXE.
I go through OK to select the images etc, but when I hit Go - I get the error
"Cant find Stub Slide.exe".
I have tried putting slide.exe from the zip file in the same folder as xmview, and also in the same fiolder as the images - but still the same error.
Any suggestions?
Re: Error : Cant find Stub Slide.exe
flip wrote:Hi,
Any suggestions?
You don't have the slide.exe in XnView folder, you have it in all packages on my website!
WHERE place it !
:arrow: flip
:) Hello !
- You might try to place slide.exe in the <Plugins> sub-directory of XnView.
:arrow: Pierre
:) Hello Pierre !
- Flip asks you for where he must place the slide.exe, not where he can get it, since he has it already !
:mrgreen: Kind regards,
flip
Thanks
Post by flip »
Thanks guys. I'll make a subfolder for the plugin.
I was trying to run the xnview exe as a standalone off a usb key.
FLip
