After updating to latest 0.94.2 64-bit, the menu font size becomes very small
hue
I just updated to latest XnView MP 0.94.2 64bit. After updating, my menu font size becomes smaller than usual.
Is there any way to change the menu font size?
Windows 10 Home 64-bit Version 1809
Re: After updating to latest 0.94.2 64-bit, the menu font size becomes very small
which version do you had before?
hue
I'm not 100% sure, but I think it's either 0.94.1 or 0.94
Rick
Go to HELP / ABOUT and the general tab will give you the exact version you are on
Rick
Rick
hue
He was asking about the version I had before, not the version I'm currently on.Rick wrote: Mon Jan 06, 2020 7:51 pm Go to HELP / ABOUT and the general tab will give you the exact version you are on
sternenatem
Similar problem here (I updated to 0.94.2 today). But it only happens when the theme "fusion dark" is active. With "fusion" and "default" all font sizes are as expected. I added some screens.
you have not same with 0.94.1?sternenatem wrote: Sun Jan 12, 2020 6:30 pm Similar problem here (I updated to 0.94.2 today). But it only happens when the theme "fusion dark" is active. With "fusion" and "default" all font sizes are as expected. I added some screens.
sternenatem
I don’t remember the exact previous version, but it was definitely something with 0.9x. I tested as follows:
0.94.2: Font size too small
0.94.1: Font size ok
0.93.1: Font size ok
So there is a change between 0.94.1 and 0.94.2.
sternenatem
Nice. I will use 0.94.1 for the meantime. Thank you for the support and this great piece of software.
sinusq
I have opposite issue after update to 0,97.1 from 0,94x.
Letters and menus are really big (all themes) comparing to previous version - so big, that I cant use batch convert without full screen mode (not all menu is visible)
Ok, i found the culprit. Please try to startsternenatem wrote: Mon Jan 13, 2020 1:06 pm Nice. I will use 0.94.1 for the meantime. Thank you for the support and this great piece of software.![]()
xnview -noDpiScaling-
Rick
I hate to ask stupid questions but where is 0.94.2? All I see is 0.94.1 posted
Rick
Rick
Are you possibly confusing 0.94.2 with 0.97.2, which hasn't been released yet?Rick wrote: Fri Oct 16, 2020 4:21 pm I hate to ask stupid questions but where is 0.94.2? All I see is 0.94.1 posted
Checking Old versions, 0.94.2 seems to have only been released as a Linux AppImage download, although the original poster does refer to Windows.
Update: Looks like a change in Pierre's numbering system: 0.942 (without the point) was released for all platforms on 2019-12-20.
