0.94.2: Rename window don't save columns width
cicciobello
Post by cicciobello »
XnView MP 0.94.2 x64
MS Windows 7 SP1 x64 (tested on 2 different PC)
Select 2 or more files
Edit -> Rename (or F2)
Adjust columns width
[OK] to apply
Press [F2] again
Actual behaviour (bug): Columns not remember choosed width
Expected behaviour: Columns remember choosed width
Re: 0.94.2: Rename window don't save columns width
cicciobello wrote: Mon Jan 06, 2020 6:16 pm Rename window don't save columns width
Is it a problem? Columns are auto resized to content...
cicciobello
Enlarging spaces between columns makes reading file names more comfortable.
My file renaming mask is frequently complex, then spaces between columns make reading well.
if i add some spaces between columns, will be better?
cicciobello
Yeah! I usually leave 4-6 mm of space to increase readability. A little space by default is fine. Thank you.
