When I'm browsing through files on my NAS via XnView and close it "too fast" so that basically not every folder was loaded, it outputs a crash notification. After relaunching it will open at the previous start session as I haven't viewed any files (newly visited pictures aren't added to the history, it is as it was before the crash without a change).
Is that problem known? I wouldn't even mind the session reset (history/folder view) but basically everytime I'm viewing my folders it crashes and the notification appears.
Crash when closing too fast
Re: Crash when closing too fast
are you able to send a crash dump?
Rhea
I sent one a few months ago, but can resent a new one if that helps?
EDIT - Uploaded a freshy generated one dumb file via crash report
