Can not delete image files
toyotadesigner
Post by toyotadesigner »
XnView MP MacOSX
Version 0.94.2 64bits (Dec 20 2019)
I can not delete any image files anymore in the folder window.
I can not copy via drag and drop files to a USB stick anymore — when I start dragging, files/thumbs are selected, but I can not drag them anywhere
Seems to be a nightmare.
hobbyists discuss new camera features
photographers discuss new software
masters discuss light
Re: Can not delete image files
do you have always this problem?
toyotadesigner
Almost always. Only few times it works, but most of the time not. I've re-installed
XnView MP MacOSX
Version 0.94.1 64bits (Nov 21 2019)
This version does not have the bug.
toyotadesigner wrote: Fri Jan 10, 2020 10:31 am Version 0.94.1 64bits (Nov 21 2019)
the 2 problems? which version of MacOSX?
toyotadesigner
macOS Catalina
Version 10.15.2 (19C57)
Yes, the two problems (they are basically the same: dragging/copying/moving) in version XnView MP 0.94.2 64bits (Dec 20 2019)
toyotadesigner wrote: Fri Jan 10, 2020 10:45 am Yes, the two problems (they are basically the same: dragging/copying/moving) in version XnView MP 0.94.2 64bits (Dec 20 2019)
On Catalina, currently there is a problem (Apple bug) to drag&drop multiple files with XnView MP 0.94.1 and 0.94.2
For the delete problem, you select a file, and delete it?
toyotadesigner
Yes, I select one or more files and then hit the delete button or in the right click menu »Delete«
As I said: Catalina is a nightmare, not only for XnView, but also for certain image editors, which report your observation of severe problems with the open and save dialogs/functions
toyotadesigner wrote: Fri Jan 10, 2020 10:53 am Yes, I select one or more files and then hit the delete button or in the right click menu »Delete«
strange i can reproduce this one
toyotadesigner
Hi Pierre, thanks a lot, the Delete is functioning now!
The auto update of the Exif Data in the thumbnails as well.
Thumbs up
toyotadesigner wrote: Mon Jan 13, 2020 11:03 am Hi Pierre, thanks a lot, the Delete is functioning now!
Please check 0.95 version
