memory leak on linux
rmtk
Post by rmtk »
It seems that there is a memory leak problem in recent versions of XnviewMP linux. When I view or edit photos in a folder containing hundreds of photos, all system memory (4gb in my computer) was eaten up in several minutes.
Re: memory leak on linux
do you reproduce?
rmtk
Post by rmtk »
Yes, always. Sometimes it took just several minutes to eat up all memory, sometimes up to a hour.
how many files do you have?
rmtk
Post by rmtk »
500-1500 in a folder
rmtk wrote: Fri Feb 07, 2020 1:03 pm 500-1500 in a folder
Strange. big files?
rmtk
Post by rmtk »
Just normal JPEGs taken by a DSLR, size 5~10MB.
It seems that it relates to thumbnail generating. I can see the memory usage of Xnview expands significantly after finish generating thumbnails of a new folder containing a lot of photos. After editing, new thumbnails generated and more memory used.
you start XnViewMP, browse this folder, and wait thumbnails generation?
rmtk
Post by rmtk »
after some more test I think memory leak accurs mostly during photo editing, instead of thumbnail generating.
rmtk
Post by rmtk »
catalog optimizing also uses 2gb+ memory and never release after finished
i don't see any memory leaks, you can have the sqlite engine that takes more and more memory...
