No drag and drop again
toyotadesigner
Post by toyotadesigner »
After installing the new version, everything seemed to work.
But now the old bug returned (as posted here: viewtopic.php?f=62&t=39886)
When I start XnView after a reboot, everything is ok. But as soon as I start another app to drag files onto it, the bug re-appears and I can not drag the selected files into the application anymore. Same bug when I insert a USB stick to drag files into it.
Closing and re-starting XnView doesn't help.
macOS Catalina Version 10.15.2 (19C57)
hobbyists discuss new camera features
photographers discuss new software
masters discuss light
Re: No drag and drop again
there is a bug in Catalina, i'll release soon a version with a workaround
toyotadesigner
Catalina is turning into a hate object :mrgreen:
toyotadesigner wrote: Mon Jan 20, 2020 11:28 am Catalina is turning into a hate object :mrgreen:
Please check 0.95 version
toyotadesigner
Installed the new version, same bug again.
Deleted ~/Library/Preferences/com.xnview.XnView.plist and — believe it or not, now it works flawlessly.
I'll keep on testing it today with dragging files to a USB stick and to other apps like Hugin or RPP (Raw Photo Processor) and give a feedback.
toyotadesigner
Nope. After a restart the drag and drop refuses to work. Same problem again.
toyotadesigner wrote: Sun Jan 26, 2020 8:39 pm Nope. After a restart the drag and drop refuses to work. Same problem again.
??? On my catalina, i have no more the problem. You select 2 files in thumbnails view and try to drag&drop?
toyotadesigner
This is strange:
Yesterday I could not drag and drop files (one, two or more) from XnView MP onto an open application (RAW converter).
Last night I shut down the Mac, and today I can drag and drop any number of files to a USB Stick or Hugin app or RPP app...
I still have to figure out when the drag and drop function will stop, maybe it's caused by a program?
Today I found there is a new com.xnview.XnView.plist in the -> Library -> Preferences folder from yesterday.
I will keep you updated!
