xnview mp 0.84 is fast, 0.85 is slow
Re: xnview mp 0.84 is fast, 0.85 is slow
BK201 wrote: Mon Feb 17, 2020 4:03 am 0.94.2, yes (not quite sure, can't remember)
which one is faster? first startup after a reboot?
BK201
Post by BK201 »
xnview wrote: Mon Feb 17, 2020 1:57 pm
0.95:
First run after computer booted: very slow (5~10 seconds, sometimes longer)
Second and later runs: fast (same as before)
0.94: can't remember :D
BK201 wrote: Thu Feb 20, 2020 4:00 am
0.95:
yes first run after reboot is always slow, DLL need to be loaded...
BK201
Post by BK201 »
xnview wrote: Tue Feb 25, 2020 10:02 am
0.95:
3~5 seconds is normal
But 10~20 seconds before the window shows itself? I can't remember any application slower than this
BK201 wrote: Fri Mar 06, 2020 3:58 pm 3~5 seconds is normal
I have not 10-20 seconds after a reboot. Please try another app using Qt libs like https://sqlitebrowser.org/
BK201
Post by BK201 »
xnview wrote: Sat Mar 07, 2020 11:13 am
Tested with "DB Browser for SQLite - .zip (no installer) for 64-bit Windows"
Same slow as xnview, first run takes 16 seconds, second and later runs takes 1 seconds to startup
spec:
BK201 wrote: Wed Mar 11, 2020 12:13 pm Same slow as xnview, first run takes 16 seconds, second and later runs takes 1 seconds to startup
Windows 10?
BK201
Post by BK201 »
xnview wrote: Wed Mar 11, 2020 6:53 pm
Windows 10?
Yes, check my attachment
Sethur
Post by Sethur »
I just tested XnViewMP 0.84 vs the current version (0.98.x) myself and I can confirm the threat author's findings: Launching into XnViewMP by double clicking a single small JPEG image in an otherwise empty directory takes about 2 seconds with the current version while it is almost instant with 0.84. It also does not seem to make a difference if an image is loaded on startup or if the application is started on its own.
I do not have many additional fonts installed. This issue is especially annoying when XnView is to be used as a quick viewer out of the Desktop (which is what I mainly use it for).
Has there been any progress on this? I went back to using XnView Classic for now, but I would really prefer MP. I don't think this is a QT5 issue per se, i.e. it should not take 2 seconds to load a QT5 UI.
Sethur wrote: Tue Sep 07, 2021 3:18 pm I do not have many additional fonts installed. This issue is especially annoying when XnView is to be used as a quick viewer out of the Desktop (which is what I mainly use it for).
Windows 10?
Sethur
Post by Sethur »
Yes, I was using windows 10.
which version? how many font files do you have?
Sethur
Post by Sethur »
xnview wrote: Fri Sep 10, 2021 4:25 pm which version? how many font files do you have?
I'm using Windows Version 10.0.19043.1165 and have 162 fonts installed.
I've updated the QT version and now there is no more problem
See issue
This problem is supposed to be fixed in XnView MP 0.99.0. Please check and confirm the bug fix here.
