I run XnView both versions 0.88 and 0.94.3 on a Mac OS Mojave 10.14.6.
My XnView interface is set up as you can see on screenshots attached.
An issue occurs on image display when the left frame loading is complete, both frame display do not show up any image and remain empty.
Screenshot-1 shows the interface while loading
Screenshot-2 shows interface when loading is complete (and nothing is displayed anymore).
Best regards.
Fixed : 0.94.3 & 0.88 : Images not displayed.
EricLovesTZTOT
EricLovesTZTOT
Re: Fixed : 0.94.3 & 0.88 : Images not displayed.
Finally, I found the origin of the problem, in the menu "View", "Filter files by" updated from "Archives" to "Images".
Sorry for the mistache. Bug fixed.
Best regards.
Best regards.
