0.95.2 Fails to Load in Linux Mint 19.3, Cinnamon
DanPF
Post by DanPF »
Subject: 0.95: Failure to load - QT5 Conflict
XnView: MP 0.95 64 bit
OS: Linux 64bit
Double Clicking Icon times out without load taking place. Loading from Terminal gives the following
"qt5ct: using qt5ct plugin
Cannot mix incompatible Qt library (version 0x50907) with this library (version 0x50c06)
Effect: Inability to run XnviewMp at all
1. Install .deb file from website
2. Double Click on launch bar item or select from Menus, or start from terminal
3. Load fails
Actual behaviour (bug): Current version fails to load at all :bug:
Expected behaviour: XnviewMp should load and run as before upgrade
Re: 0.95.2 Fails to Load in Linux Mint 19.3, Cinnamon
and with the tgz?
DanPF
Post by DanPF »
xnview wrote: Fri Jan 24, 2020 8:08 amand with the tgz?
Sorry, I only use the .deb files on any software these days.
I regressed to 94.3 and that does work. Interestingly If I start from the Terminal, with sudo, .95 does load
DanPF wrote: Fri Jan 24, 2020 5:45 pm
when you try to start it from a console, messages?
zygos29
Post by zygos29 »
Same problem here.. Both tgz and deb file gives this message from console
Paka
Post by Paka »
Are prior versions available for download? I've been unable to locate them.
I'm unable to load Classic XnView as well.
The problem is with the .deb package, AppImage and running from the script from console.
Error:
Aborted
Runnning with:
Debian 4.9.189-3+deb9u2 (2019-11-11)
Linux Mint Debian Edition (LMDE) 3 Cindy
djcj
Post by djcj »
I get the same with AppImage and tarball:
Aborted (core dumped)
For those interested, you can get previous versions here: https://download.xnview.com/old_versions/?C=M;O=D
I assume some Qt library is missing, it tries to load it from the system and they're not compatible?
Update:
The lib directory contains libQt5WebKit.so.5.9.0 and libQt5WebKitWidgets.so.5.9.0. I guess those are the ones which need an update.
djcj wrote: Sun Jan 26, 2020 11:35 am I assume some Qt library is missing, it tries to load it from the system and they're not compatible?
Update:
No missing libraries, the problem is that i use Qt 5.12 and Qt 5.9 is installed, i try to find a workaround
i've updated the package, now it works on system with QT 5.9
fractl
Post by fractl »
xnview wrote: Tue Jan 28, 2020 11:56 am i've updated the package, now it works on system with QT 5.9
Which package have you updated? I've just installed the .deb which was flagged as a problem by @DanPF and I have the same problem. As he noted, I can run it if I use the superuser prefix sudo.
XnView MP Linux
Version 0.95 64bits (Jan 26 2020)
Libformat version 7.36
OS: Ubuntu 18.04.3 LTS
fractl wrote: Tue Jan 28, 2020 12:58 pm
i've fixed the TGZ, if you start xnview from terminal which message do you have?
fractl
Post by fractl »
I'm not much of an expert with TGZ files but I've unpacked it into my home directory, and not having any luck running it:
julie@julie:~/Scratch/XnView$ ./xnview.sh
This is exactly the same error as I was getting before. I can run it as a superuser and just to double check, the About box info looks the same:
XnView MP Linux
fractl wrote: Tue Jan 28, 2020 6:54 pm I'm not much of an expert with TGZ files but I've unpacked it into my home directory, and not having any luck running it:
XnView MP Linux
I've just installed a ubuntu 18.04 with Qt 5.9.5, and no problem to start XnView from .deb or .tgz
do you have qt5ct?
MaxMeier
Post by MaxMeier »
Hallo all,
the same problem exists with a fresh new installation of Linux MINT 19.3 xfce 64bit.
XnView MP 0.95 was installed from the Linux DEB 64bit.
The XnView version 0.94.x is working properly.
Thanks for the support
Max
juozas
Post by juozas »
xnview wrote: Wed Jan 29, 2020 9:19 am I've just installed a ubuntu 18.04 with Qt 5.9.5, and no problem to start XnView from .deb or .tgz
do you have qt5ct?
On my Ubuntu 18.04 installation with latest updates it does not work either, as qt5ct is already installed.
Edit: I had to modify /etc/X11/Xsession.d/56xubuntu-session and set the QT_QPA_PLATFORMTHEME variable to qt5ct to fix qt5ct invocation and by that get xnview working otherwise it would throw the same error like before, so make sure QT_QPA_PLATFORMTHEME is set to qt5ct or qt5ct program might not work and xnview would not work too.
# Set default environment vars in Xubuntu
if [ "$DESKTOP_SESSION" = xubuntu ]; then
    # Disable GTK 3.16 overlay scrollbars
    export GTK_OVERLAY_SCROLLING=0
    # QT5 apps to use GTK style (disabled)
    #export QT_QPA_PLATFORMTHEME=gtk2
    # Use qt5ct for QT5
    export QT_QPA_PLATFORMTHEME=qt5ct
    # Workaround clutter issue (LP: #1462445)
    export CLUTTER_BACKEND=x11
fi
Сделано в СССР
