0.95: MNG animations not playing, even though they can be read.
Himekaidou
Post by Himekaidou »
XnView: MP 0.95 - 64 bit
OS: Windows 10 64-bit
MNG animations will load and display the first frame only, instead of animating. The properties box in the browser detects the correct total number of frames though.
I have attached two sample MNGs that are animated to test with, if need be.
Effect: MNG animations do not play.
1. Try to preview the MNG in either XnViewMP's browser, or by opening it fully.
Actual behaviour (bug): The animation does not play, it only statically shows the first frame. :bug:
Expected behaviour: The animation plays normally.
Re: 0.95: MNG animations not playing, even though they can be read.
MNG animation is not supported in XnView MP
