Cannot install XnConvert on Fedora 31
alex.seidanis
Post by alex.seidanis »
tried to install XnConvert on my Fedora 31 but I get:
Error:
 Problem: conflicting requests
  - nothing provides libQt5Core.so.5(Qt_5_PRIVATE_API)(64bit) needed by xnconvert-1.82-2.x86_64
  - nothing provides libQt5EglFSDeviceIntegration.so.5(Qt_5_PRIVATE_API)(64bit) needed by xnconvert-1.82-2.x86_64
  - nothing provides libQt5Gui.so.5(Qt_5_PRIVATE_API)(64bit) needed by xnconvert-1.82-2.x86_64
  - nothing provides libQt5Network.so.5(Qt_5_PRIVATE_API)(64bit) needed by xnconvert-1.82-2.x86_64
  - nothing provides libQt5XcbQpa.so.5(Qt_5_PRIVATE_API)(64bit) needed by xnconvert-1.82-2.x86_64
(try to add '--skip-broken' to skip uninstallable packages)
I installed qt5-qtbase, qt5-qtbase-devel, qt5, qt5-devel, qt, qt-devel, nothing seems to do the trick.
Any assistance around this would be sincerely appreciated, thanks.
Re: Cannot install XnConvert on Fedora 31
when you try to install the .deb? XnConvert comes with QT libs, no need to install them
alex.seidanis
Thanks for your response Pierre.
Fedora is an rpm-based distro, doesn't know what to do with deb files, as far as I know anyway.
please try the tgz package
alex.seidanis
I got the following errors:
./XnConvert
./XnConvert: /lib64/libQt5Network.so.5: version `Qt_5_PRIVATE_API' not found (required by ./XnConvert)
./xnconvert.sh
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
./xnconvert.sh: line 5: 53019 Aborted                 (core dumped) "$dirname"/XnConvert "$@"
it's the same problem
you need to remove lib/libfreetype.* from XnConvert package
alex.seidanis
Brilliant! It works now!
Thanks for all the time and effort you put into this Pierre, I truly appreciate it.
