in the newest Version of XnView I could't find the option "Hide Cursor in Slide-Show". This was a nice feature. Is there somebody, who know, where I can find this option? Thank's!
Greetings
Stengel
Hide Mouse Cursor in Slide show
Re: Hide the Curser in Dia-Show
The cursor is hidden after some seconds...Stengel wrote:Hello,
in the newest Version of XnView I could't find the option "Hide Curser in Slide-Show". This was a nice feature. Is there somebody, who know, where I can find this option? Thank's!
Wolfgang
xnview wrote:The cursor is hidden after some seconds...Stengel wrote:Hello,
In my Version 1.80.3 the Cursor do not appear. What is wrong and what can I do?
If you move the mouse, cursor doesn't appear??Wolfgang wrote:xnview wrote:The cursor is hidden after some seconds...Stengel wrote:Hello,
Wolfgang, could you please check in which mode you are in? The cursor is automatically hidden during Slide shows or in Fullscreen mode. If your image is shown within a window with titlebar and borders it's very likely that you are not in a slide show or fullscreen mode.Wolfgang wrote:...
helmut wrote:Wolfgang, could you please check in which mode you are in? The cursor is automatically hidden during Slide shows or in Fullscreen mode. If your image is shown within a window with titlebar and borders it's very likely that you are not in a slide show or fullscreen mode.Wolfgang wrote:...
I’m always in the slide show mode. The Curser will automatically hidden when I start the slide show from the browser with the right mouse button. When I start the slide show from the slide show XnView title bar the cursor is not hidden. Also it is not hidden when I start from “Open Slide Show” (Dia-Show öffnen).
Thank’s Wolfgang
I've just tested, and all is ok. Someone with the same problem?Anonymous wrote:helmut wrote:Wolfgang, could you please check in which mode you are in? The cursor is automatically hidden during Slide shows or in Fullscreen mode. If your image is shown within a window with titlebar and borders it's very likely that you are not in a slide show or fullscreen mode.Wolfgang wrote:...
Sar
The slide show in viewer is a Quick Slide Show. Here, the cursor is currently not hidden. In Quick Slide show (which does not use fullscreen) there are so many other things disturbing (Window title and frame), so I wonder whether hiding the cursor makes much difference.Sar wrote:The cursor is not hidden when I start a slideshow from the viewer.
No problem within the browser.
Sar
I understand that, however I mean a fullscreen slideshow (CTRL+L).helmut wrote:The slide show in viewer is a Quick Slide Show. Here, the cursor is currently not hidden. In Quick Slide show (which does not use fullscreen) there are so many other things disturbing (Window title and frame), so I wonder whether hiding the cursor makes much difference.Sar wrote:The cursor is not hidden when I start a slideshow from the viewer.
@yourservice
Re: Hide Mouse Cursor in Slide show
I have the same, slide show, 6 seconds and after playing the mouse doesn't disappear.
Version 1.9.2 64-bit (Windows) - Libformat 7.226
