"This application failed to start because no Qt platform plugin could be initialized" [Windows 10]
gm649
hi
xnview mp latest version 0.95 not work for me
when i run xnview mp ,it says
"This application failed to start because no Qt platform plugin could be initialized:
im using windows 10 professional 64 bits
version from 0.94.1 to 0.94.3 works fine with me
Thanks
Thanks
Re: "This application failed to start because no Qt platform plugin could be initialized"
which distribution? please check this post
gm649
i tried both (i downloaded about an hour ago)
https://download.xnview.com/XnViewMP-win-x64.exe
https://download.xnview.com/XnViewMP-win-x64.zip
and they threw the same error
i read that thread and i have no idea what i have to do because my Os is windows ,not linux
can you please help
thank you
Sorry, i've not seen that you are on Windows.
Which version windows 10?
gm649
thank you for your supportxnview wrote: Sun Feb 09, 2020 2:52 pm Sorry, i've not seen that you are on Windows.
hope it will be fixed soon
Which version, please?
You are the first user with such problem...
gm649
maybe it because im using older version of windows 10
im using build 10240 ,
on other pc,xnview mp runs fine on latest version of windows 10
is it possible to make it works on older version (in my case is 10240 ) ?
Thanks
I have no 10240 build, perhaps you need to download the x64 crtgm649 wrote: Thu Feb 13, 2020 9:45 pm im using build 10240 ,
gm649
Thank you for the help, may i ask for the download link of x64 crt?xnview wrote: Tue Feb 18, 2020 1:46 pmI have no 10240 build, perhaps you need to download the x64 crtgm649 wrote: Thu Feb 13, 2020 9:45 pm im using build 10240 ,
do you mean this ?
https://www.microsoft.com/en-us/downloa ... x?id=48234
Thanks again
gm649
gm649
Thank you , i have no idea what dll missing
but i tried install the xnview MP version from 0.94.1 to 0.94.3 ,they still work fine
they dont' use same version of Qt libsgm649 wrote: Tue Feb 18, 2020 5:23 pm but i tried install the xnview MP version from 0.94.1 to 0.94.3 ,they still work fine
gm649
i see, is there anyway for me to fix this ? install Qt (i dont know where to download it) or any software ?
Thank you
