video preview on transparent video
MitchellK
Post by MitchellK »
When previewing video files in XN View MP, if that video file has an alpha channel (ie. is transparent) the frames stack on top of each other (see attached screenshot of a clip of snow falling)
It looks like the image buffer isn't cleared before drawing the next frame or something. Is this a bug? is there a fix for this? thanks for your help
Re: video preview on transparent video
please send me a video file
MitchellK
Post by MitchellK »
Here is a file that has the properties I described, along with what it looks like in XnView MP after playing it back.
with 0.95?
MitchellK
Post by MitchellK »
I had been running 0.93, but can confirm that the issue persists in 0.95.
From about screen:
XnView MP Windows
Version 0.95 64bits (Jan 15 2020)
Libformat version 7.36
MitchellK wrote: Sun Mar 01, 2020 9:56 am I had been running 0.93, but can confirm that the issue persists in 0.95.
From about screen:
XnView MP Windows
Seems to be related to video driver, i have no problem here
MitchellK
Post by MitchellK »
Any suggestions on how to fix?
Doesn't happen in XnView by the way, just XnView MP. Which is what made me think it might have been a bug
MitchellK wrote: Tue Mar 03, 2020 5:34 am Doesn't happen in XnView by the way, just XnView MP. Which is what made me think it might have been a bug
Classic use installed codec, XnView MP used ffmpeg based api
