0.95 linux: "Explorer" no longer working
rmtk
Post by rmtk »
I'm using Ubuntu with Mate desktop. Until 0.94 I can open the photo folder with Caja file manager with the "explorer" command. However it is no longer working in 0.95.
Not yet tested with other file managers.
Re: 0.95 linux: "Explorer" no longer working
if you start it from a terminal, do you see error message?
rmtk
Post by rmtk »
caja: symbol lookup error: /lib/x86_64-linux-gnu/libcairo.so.2: undefined symbol: FT_Get_Var_Design_Coordinates
which version of ubuntu?
rmtk
Post by rmtk »
19.10
rmtk
Post by rmtk »
open with associated problem doesn't work as well, similiar error:
engrampa: symbol lookup error: /lib/x86_64-linux-gnu/libcairo.so.2: undefined symbol: FT_Get_Var_Design_Coordinates
rmtk
Post by rmtk »
I fix it by removing libfreetype.so.6 from lib.
There is an incompatibility between the libfreetype provided and some system libraries (libcairo or something else).
