Info Pane, Properties Tab showing wrong image width and height
Calvinsalt
The image width and height information shows on the properties tab in Info pane is not correct. I seems to show the image width and height of the next/previous image. See attached screen capture.
Re: Info Pane, Properties Tab showing wrong image width and height
i can't reproduce, do you reproduce for each image files?
Calvinsalt
I try today. It is ok now. Maybe it is just a crash last session. Thanks for the prompt reply.
