0.95 Linux: Focus lost after "Copy to..."
Stefan1
Post by Stefan1 »
XnView: MP 0.95 - 64 bit
OS: Linux 64bit, Ubuntu 18.04.4 LTS
Short description: After using "Copy to..." (Alt-C) with a file, the file is not fully selected any more (but it looks like it is selected).
Effect: After said operation, "Next file" (SPACE) doesn't work any more. Also, "Copy to..." doesn't work any more. Interestingly, "Previous/next file" (Left/Right) still works. "Enter" also works and pressing "Enter" twice (open viewer/close viewer) fixes the problem. Also interesting: this bug seems to happen only when the file is copied without any further confirmation dialogue. If the confirmation dialogue for overwriting/skipping/replacing is shown, the bug doesn't happen. This bug doesn't only happen in browser view, but also in viewer or fullscreen mode.
To reproduce (with original configuration):
1. In the browser view, select a file using keyboard or mouse
2. Press Alt-C
3. Select some location where the file doesn't exist yet, using the keyboard (e.g. enter "..") or using a cached location, and press "Enter"
4. Press SPACE
Actual behaviour: Nothing happens :bug:
Expected behaviour: Next file is selected
Re: 0.95 Linux: Focus lost after "Copy to..."
I don't understand "Copy to" is Alt+C,, Copy is Ctrl+C???
Stefan1
Post by Stefan1 »
Sorry. I meant "Alt-C". Fixed the description.
Stefan1 wrote: Sun Feb 23, 2020 12:18 pm 4. Press SPACE
You means that you are in edit mode not browser mode, right?
Stefan1
Post by Stefan1 »
No, this happens in browser mode. Pressing SPACE for next file (and other things) don't work after "Copy to..."
Stefan1 wrote: Sat Mar 14, 2020 11:35 am No, this happens in browser mode. Pressing SPACE for next file (and other things) don't work after "Copy to..."
i can't reproduce, arrows works
