[Help] "close other tabs" command ?
gm649
Post by gm649 »
Hi , i want to add "close other tabs" button (and keyboard shortcut if possible)
I read the command list but i can't find any xnview command relate to it
Any help would be much appreciated
Thanks
Rick
Re: [Help] "close other tabs" command ?
Post by Rick »
There is not a close other tabs option as far as I know but there is a close other tabs by right clicking on any tab
Then there is a close button on any image in view mode plus control + W closes the tab you are in
Rick
gm649
Post by gm649 »
Rick wrote: Fri Feb 28, 2020 7:16 pm There is not a close other tabs option as far as I know but there is a close other tabs by right clicking on any tab
Thank you very much, i knew it
i dont know why there is no command for it
maybe i have to post on suggestion section for "close other tab" command
Rick
Post by Rick »
gm649 wrote: Sat Feb 29, 2020 1:02 am maybe i have to post on suggestion section for "close other tab" command
I will support it when you get it posted
Rick
gm649
Post by gm649 »
Rick wrote: Sat Feb 29, 2020 7:52 pm
Thank you very much, i posted here viewtopic.php?f=60&t=40100
