For a while now with multiple updates of the software, the first image in a slideshow isn't being centered and is offset in the bottom-left corner. I've uninstalled (cleanly) and re-installed the software, re-created the slideshow, checked and unchecked the "center image" option but nothing makes a difference. It is happening in a situation where we have multiple monitors on the computer. At first, I had a 'dummy' image that I had as the first picture in the slideshow and just dealt with it, but the slideshow has been changed now and I don't have the luxury of a 'dummy' image.
Any ideas why the first (and only the first) picture is getting skewed off-screen?
PS - I also previously had the slideshow set on a constant loop and again it would only happen to the FIRST image, even when looping and repeating the slideshow it would be fine. But the way things are set up now, the slideshow is stopped and then restarted, so it's not looping like before.
God bless,
~Mark
Problem with 1st Picture in Slideshow Offset in Bottom-Left Corner
Zeoran
Re: Problem with 1st Picture in Slideshow Offset in Bottom-Left Corner
could you post a screenshot of the slideshow dialog?
