0.95 Windows 10: Lepton files with unicode names cannot be opened
winterNebs
Subject: 0.95 : Lepton files with unicode names cannot be opened
XnView: MP 0.95- 64 bit
OS: Windows 10 64bit
.lep files with unicode names (like "あり.lep") cannot be opened.
Effect: Those files cannot be used.
1. Convert a jpg to .lep using the lepton exe from https://github.com/dropbox/lepton/releases (I believe this is the same one used to convert back by XnView)
2. Rename the resulting .lep to "あり.lep"
3. The .lep cannot be viewed anymore
Actual behaviour (bug): Cannot view the .lep. (I believe this is a problem with the compiler used to build the https://github.com/dropbox/lepton/releases, since it cannot read any files with unicode in the path.
Not sure if this is an issue on linux, if not then maybe we can recompile the windows executable?)
Expected behaviour: Should be able to view the .lep in XnViewMP
Re: 0.95 Windows 10: Lepton files with unicode names cannot be opened
winterNebs
Awesome that was fast
This problem is supposed to be fixed in XnView MP 0.96.1. Please check and confirm the bug fix here.
winterNebs
winterNebs
Oops my bad I actually was viewing a .jpg, the bug still persists for me.I noticed the lepton.exe was not updated in the plugins folder. Maybe that is why? (using the installer)
No preview in browser? I have no problemwinterNebs wrote: Thu Apr 23, 2020 12:00 pm Oops my bad I actually was viewing a .jpg, the bug still persists for me.I noticed the lepton.exe was not updated in the plugins folder. Maybe that is why? (using the installer)
winterNebs
https://i.imgur.com/lnJ7GWy.pngxnview wrote: Thu Apr 23, 2020 3:00 pmNo preview in browser? I have no problemwinterNebs wrote: Thu Apr 23, 2020 12:00 pm Oops my bad I actually was viewing a .jpg, the bug still persists for me.I noticed the lepton.exe was not updated in the plugins folder. Maybe that is why? (using the installer)
Yes seems to still be an issue for me
you rename it and no more problem?
winterNebs
Renaming a file will work, but having to rename thousands of images, especially with not an easy way to romanize the names will take a lot of work.
i don't understand, with lastest version
winterNebs
I reinstalled and the issue persists still,
I am on windows 10, and created this image with the latest release from https://github.com/dropbox/lepton/releases
Not sure what's different here
could you send me it?winterNebs wrote: Fri May 01, 2020 10:55 pm I reinstalled and the issue persists still,
winterNebs
I've tried with this exe, but no problem with output file
