XnView MP 0.95 is not working on Crostini Buster (Versie 81.0.4044.72 (Officiële build) beta (64-bits)).
XnView does not startup at all.
Any suggestions?
XnView MP on Chromebook Debian Buster not working
frank_58
Re: XnView MP on Chromebook Debian Buster not working
if you start it from terminal?
frank_58
No, there are missing some libs I think on buster. Tried V0.96 same problem.
/opt/XnView/XnView: error while loading shared libraries: libpulse-mainloop-glib.so.0: cannot open shared object file: No such file or directory
frank_58
Problem solved: sudo apt install libpuls-dev
After installing evertything works.
Thanks for the tip!
Thanks for the tip!
frank_58
Xnview v0.96 on Chromebook Crostini Debian Buster is very slow!!!
Where can I download earlier versions?
Earlier versionsfrank_58 wrote: Thu Mar 26, 2020 9:32 am Xnview v0.96 on Chromebook Crostini Debian Buster is very slow!!!
frank_58
Tried several older editions but no performance at all.
XnView MP works great under Crouton (Debian Stretch XFCE), but not on Crostini ( Debian Buster).
Any suggestions how to speed up XNView MP running Crostini (Debian Buster)?
Thanks in advance.
Thanks in advance.
what is slow, the general UI?frank_58 wrote: Mon Mar 30, 2020 11:57 am Any suggestions how to speed up XNView MP running Crostini (Debian Buster)?
frank_58
UI works but not fast
But opening directories, pictures ect is extreme slow.
Using Shotwell under crostini debian buster is very fast.
XNview under crouton same Lenovo S340 chromebook is very fast
thumbnails building?
