Cannot change shortcut "Open with > Associated Program"
oredaze
Post by oredaze »
I don't know if this is very new, but I think it wasn't a problem in old versions.
I want to use the F3 key but it conflicts with "Open with > Associated Program" and that one is not present in the settings, so it cannot be changed.
Also on a side note if I set a shortcut to "None" it does NOT remove anything, so that's an other bug.
Re: Cannot change shortcut "Open with > Associated Program"
oredaze wrote: Mon Mar 23, 2020 12:44 pm I want to use the F3 key but it conflicts with "Open with > Associated Program" and that one is not present in the settings, so it cannot be changed.
F3 can't be reassigned, always used by 'Associate Program'
could you explain me more?
oredaze
Post by oredaze »
Yes, but can we please be allowed to do that in the future, because I use F1-4 for my various zooming across all programs.
When I want to disable a shortcut I set it to NONE in the settings, that appears to have no effect.
oredaze wrote: Wed Apr 01, 2020 6:59 pm When I want to disable a shortcut I set it to NONE in the settings, that appears to have no effect.
which one? in edit or browser mode?
oredaze
Post by oredaze »
Both.
Actually I found that if you restart the program it gets applied properly. Strange behavior.
