"Program current in use", cannot delete folder
gm649
Post by gm649 »
when I open image in folder "A"
then i exit view mode and browse to different folder (i intend to delete folder "a" ,so i browse to different folder)
then I delete the folder "A" , windows explorer tells me that folder currently in use
I have to exit xnviewmp to delete that folder
is there anyway to delete that folder without quit xnviewMP ?
Thanks
Rick
Re: "Program current in use", cannot delete folder
Post by Rick »
I have seen this. First make sure you are out of the view mode and that the tab is still not on the tab bar
If that doesn't do it then you might consider using Lockhunter which will unlock and optionally delete the item and show you the locking process first. If it is XnView still locking it you can delete without crashing the program. It installs to the right click menu
Just google lockhunter but if you need a link I can get one for you
This is a long standing Windows issue that has improved over the years but still annoys us
Rick
gm649
Post by gm649 »
thank you for the help, i 'm using unlocker program too
i guess it's a bug of xnviewmp, so i posted in bug section
Rick
Post by Rick »
Well he may see if anything can be done to help XnView to release folders and files but as I said it is an operating system issue for the most part
Rick
gm649
Post by gm649 »
Rick wrote: Fri Mar 27, 2020 2:33 pm Well he may see if anything can be done to help XnView to release folders and files but as I said it is an operating system issue for the most part
yes, that's right , man
