[Solved]"Program current in use", cannot delete folder
gm649
Post by gm649 »
Hi ,
I'm not sure this can be considered a bug ,but i hope it can be fixed:
how to reproduce :
when I open image in folder "A"
then i exit view mode and browse to different folder (i intend to delete folder "a" ,so i browse to different folder)
then I delete the folder "A" , windows explorer tells me that folder currently in use
I have to exit xnviewmp to delete that folder
(i want to delete that folder without quit xnviewMP)
Thanks
Re: "Program current in use", cannot delete folder
windows 10? I can't reproduce with 0.96
gm649
Post by gm649 »
xnview wrote: Tue Mar 31, 2020 4:17 pm windows 10? I can't reproduce with 0.96
sorry i made a mistake, i said "windows explorer" but actually im using xyplorer (which is a file manager program https://www.xyplorer.com/)
if i delete by windows explorer, it works fine
but it has problem with xyplorer ,maybe it because of xyplorer itself,not xnview mp
sorry my bad, i mark this topic solved
Thank you very much
