Browser open with last directory
Steryl
Post by Steryl »
I was wondering if there is a option to turn off the 'open with last directory' feature.
When I want to scan an item, I open the browser and I just want to start clean and have all folders closed.
Re: Browser open with last directory
You can set the startup directory of XnView:
In Menu "Tools » Options" | "General | Operations you will find "Startup directory". Here you select (o) Specified and select the desired top level folder.
Steryl
Post by Steryl »
Thank you that works.
