New user here - could use some support! First, hope you all are well.
I'm trying to set up my files and it appears that I'm not seeing what I thought I could see in the Tree panel - I have an external harddrive installed on my Mac but I can't locate it.
Are there any videos or youtube help for beginners that I am not seeing?
Thank you for your kind help.
SJDodd
External hard drive not displayed in tree panel [Mac]
SJDodd
Re: New User Help
even if you restart XnView?
SJDodd
Re: New User Help
No - no luck. I feel there must be some instructions or a manual or something - this can't be that hard! I formerly used Picasa, is anyone familiar with how the two are similar?
Re: New User Help
you have not it under 'Volumes'?
