Sugg.: "Save log file as ..."
Peter2
Post by Peter2 »
The log (status) can be "copied and pasted" to a log-file, but it would be fine if there were a function "save log (status) as ..." text file.
Maybe you can add some header lines like
- started at: date / time
- started by: username
- started from: PCName
(Luxury version:
- current settings: .....)
- logged data
- footer lines: like now plus
- finished at: date / time
Re: Sugg.: "Save log file as ..."
ok, a button 'save log'?
Peter2
Post by Peter2 »
Yes, should be fine.
This problem is supposed to be fixed in XnView MP 0.96.1. Please check and confirm the bug fix here.
Peter2
Post by Peter2 »
Basically fine, thanks.
maybe you can consider this:
- Button instead of context menu
- the data/time format will come from regional settings, right?
- add these header lines:
- Luxury: add reason of "finished" (independent from Log-file)
- Finished because everything is done
- Finshed because "stop" was pressed
