I am using Linux Manjaro KDE. I would like to be able to attach multiple images to Thunderbird mail client. There is no problem when I define Thunderbird as a external program and use command having selected image → open with → thunderbird. If I choose one image - no problem. But what should be done to be able to send multiple images? I select many but only the first one is attached. Any sugestion?
Send images by email using Thunderbird
Re: Send images by email using Thunderbird
right currently only the first one is sent
ra-dio
OK, thanks for the confirmation, but is there any solution for attaching multiple images?
