Black/empty JPGs in slideshow
bluejay
Post by bluejay »
just tried 1.8 after using 1.68 for some time
Unfortunately running slide show does not show all images. Some JPG files are ahown whilst others appear as black screen with file name only
Running 98SE
Had no problem in previous version and have removed and replaced both twice.
The files in the directory are two sizes of jpg from two different cameras and different resolutions but no problem elsewhere
Tried file associations but that did nothing
Any ideas please
Sample(s) ?
:) Good morning,
- Please, could you display a faulty image JPG here, or set a link from which it could be reached, in order to test ? Thank you.
:mrgreen: Kind regards,
bluejay wrote:just tried 1.8 after using 1.68 for some time
Running 98SE
Any ideas please
A known bug, please uncheck "high quality"
xnview wrote:...
Not known to me. :o
I'm tempted to put this one on the list of "Must fixes", but if the workaround "Uncheckking high quality" works it's not too bad. This should be fixed in 1.82.
bluejay
Post by bluejay »
Yes,
thanks, works okay now
Must congratulate all who work so hard that we may enjoy ourselves with an excellent program
Will try it in Linux next
