Refresh not working after batch rename.
Akovia
Post by Akovia »
I use the Custom Filter option to exclude *.tbn files from view.
If I batch rename a group of images from jpg to tbn and try to refresh the view to exclude the new tbn files from view, it doesn't work. I have to move to another directory and back to to have those images hidden from view.
Here's a short video of it happening.
https://mega.nz/file/tQh1yaZL#P-ZWU-MQM ... QsU_DfsCAM
Arch Linux
XnView MP
Re: Refresh not working after batch rename.
right, or you need to click again on Filter>Custom
Akovia
Post by Akovia »
xnview wrote: Thu Apr 16, 2020 2:04 pm right, or you need to click again on Filter>Custom
So this is by design?
I thought refresh would truly reload all the images again the same as moving away from the directory and back again.
Thanks for clearing that up.
Cheers
Arch Linux
XnView MP
no an error
guzmelek
Post by guzmelek »
I actually have an opposite issue :)
For example:
- If I have a bunch of files selected for renaming
- and I notice an odd, incorrectly rotated, file
- so i want to rename selected files first, so I don't loose the selection
- rotate the odd file
- and continue going through the list from the place where I left off.
However, I am getting sent to the top of the directory and have to scroll down to the previous position again... :/
It would be nice to have an option to toggle auto-refresh on and off.
P.S. This is my first post here, so I wanted to thanks Pierre for the amazing programs! Merci beaucoup! :)
